First water cooled build Mountain Mods case Please help...
Goggle Eye
First Thank you for responses.
Windows 7 Ultimate 64 bit
Case Mountain Mods Asencion Extended, Front Panel Trinity 9 fans, 6 5.25 bays. Left Side Big Window, Top Big Window, M/Board Tray HTX ATX extended Vertical, Rear of case 3 case fans in verticlal position above PSU, 1 fan on left center back panel. Can use two power supplies Bottom right corner/Top left corner.
I want to up Load pics as I do the build. I will probably assemble and dissasemble several times for best in running the loops and wire managment.
Power Supplies:
Koolance water cooled PSU one 1000w multi rails or Coarsair Gold 1200w PSU The Coarsair?
M/Board Asus Rampage lll extreme or Evga 58X Classified?
GPU 2 Evga GTX 580 Hydro FTW Or Asus 5870 2 Gig each with water blocks?
CPU I7-975 3.33 Think the CPU will work ok, Can be over clocked. just not sure how?
One set of three sticks of Coarsair memory 2000mhz = 6 gig or Coarsair memory 1600mhz 3 sticks = 12 gig?
2 Coarsair 120 Gig each SSD raid 0, one 3 gig Velocity Raptor for graphic editing, and games with 2 terrabite hard drive for music, picts and movies and back up for C:drive or
2-300 gig Velocity Raptors Raid 0 with 2 terabite HD for back up?
Creative Labs Sound blaster Fatalaty 1 sound card or,
Please recomend a vary good sound card for Music, Games, Blue Ray Movies?
What 5.25 bay device should I use to read the temps only for the CPU, Graphic cards, N and S bridge?
I have one Lamptron 6 chanel Fan controler with temp display. uses Dallas wire.
Water Cooling:
2 Black Ice SR1 360 rads or 4 360 rads?
900 RPM to 1000 RPM. 45 to 60 CFM. Scythe Fans.
Ek or Bits Power reseivors 250s?
Pumps 2 Swiftech or Uber 655 (Swiftech Pumps highly modified).
Should I run a speed controler on the pumps to regulate the pump speed or plug in direct to the PSU?
I am using:
CPU Block Swiftech
M/Board Bits Power full block with one Block on Voltagen Reg.
I have 9 inches on either side of the M/board tray. For pumps and reseivors.
Should I mount on same side as M/Board or oppisite side?
I can run the loops thru the m/board tray, Plenty of room.
Running distilled water with 2 coils of 99.9 percent silver. Should I run any other additives to help eliminate agaie and funguss? Tubing on the loops is black. No Florecent lights.
Wow so many questions I hope I did not confuse any one.
I really want to choose the best hardware. I only up grade every 5 to 7 years. Sticular on perfection.
This is my first build using liquid cooling. I will use distilled water with 99.9% silver in each loop. making my own coils.
I think I will need to change water every three months according to what I have read on this sight and other sights.
I didnt mean too write a novel LoL,
Thanks for the input. I am sure everyone inputs will give myself and others ideas and thoughts on building systems.
Goggle Eye
not sure what I did wrong when I posted. I see the e mail folder has a question mark over it. can I remove this so I recieive e mails on this post?
Thans
