First water cooling attempt
Jan 16, 2019
So as you read this will be my first water cooling attempt. I'm wanting to see if there is anything i am missing.
Also I'm only doing the CPU
Mobo- MSI b75ma-45p or something like that
CPU- i5 3570k
Case- thermaltake core V21
Parts list(from amazon)
Pump- Thermaltake Pacific LCS PR22 Pump/res
Block- Universal block from amazon BXQINLENX is the manu
Rad- XSPC EX140
Fittings- XSPC G1/4 to 3/8 6 pack
Tubing- same manu as the block ~6 1/2ft of 3/8 X 1/2 soft tubing clear
As of the moment I'm pretty sure that is all i will need, but again this is the first attempt.
Yes, i could have gone with a better block. But my budget for this experiment is $200.
Any thoughts or tips for doing this in this particular case are welcome. Also if i am missing anything, please chime in.
TBH this pc is my "test" pc. this is where i try all of my new mods before i do them to my main. Keep in mind my main is in the same case as my test pc, so if this all goes to plan, i will simply move parts over to my main
