Background - Looking to build a WC loop for an older build that will be able to be re-used (mostly) in future builds.
Current Setup:
Case - CM HAF X
CPU - AMD 1100T @ 4.11 OC
CPU Cooler - CM V8
GPU - MSI R9 290 Rev 2.2 OC
MOBO - ASUS Sabertooth 990FX
PSU - Seasonic 1050 (Used to have a crossfire setup)
Here are the parts that I found that I think would work.
Please let me know if you see anything that is incorrect or if you have better recommendations.
I am planning on doing a single loop build, with connection to the CPU and 1 GPU.
I want it to be internal, with a push/pull fan setup. (So that means rad must be under 50mm width)
CPU Block: EK-Supremacy EVO - Nickel
Res: XSPC 5.25" Bay Reservoir
Pump: Swiftech MCP35X Pump
Rad fans: Rosewill Hyperborea 140mm Fan (Need 3)
Rad: Alphacool NexXxoS XT45 Full Copper Radiator 420
GPU Block: EK MSI / Gigabyte Radeon R9-290X VGA Liquid Cooling Block Rev 2.0
GPU Plate: EK R9-290X VGA Liquid Cooling RAM Backplate
GPU misc: EK R9-290X VGA Liquid Cooling Reinforcer
Tubing/Fittings: Don't think it really matters what I choose, but will be 1/2"in or 7/16"in and 3/4"od
Thanks in advance WC gurus.
Current Setup:
Case - CM HAF X
CPU Cooler - CM V8
