• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
first water cooling venture
GeneralJim25
350
Ok so im at work at the moment with no access to a computer so bear with me lol i spent all lunch break reading up on custom water cooling (including the sticky thread) and i think i have a decent grasp on it. Anyways i was looking on frozencpu at some kits. This one caught my eye http://www.frozencpu.com/products/18964/ex-wat-249/EK_L240_Complete_Dual_120mm_Liquid_Cooling_Kit_EK-KIT_L240.html
Anyways my main questions arr what is this a good kit and can i add a water block for a Gtx 670. And if i can add on to it would i need. Also can i get a recommendation on a resevoir? I feel this venture would go more smoothly with one. Also my case i a AZZA Hurrican 3000. Would this work in this case? Thnx in advance.
Buzz247
962
111
As far as the kit goes, I'm not going to get in a battle with a fanboi and whether it's good or bad. The key here is the word "starter". These are basic components. Not high end longevity or performance products. For that price I think you may be happier with a swiftech, xspc, or closed loop kit.
Choosing components is sometimes performance, fit, or preference issue. A reservoir is fit and personal preference. Incidentally, that kit has a pump/res combo. Most kits do. Not all res have pumps built in, for a reason
As far as the case... how comfortable are you modding? Lol. Being that a hurrican 2000 and fusion 3000 exist, but not a hurrican 3000, hard to say what will work without knowing which you have. Assuming hurrican 2000, it has ports in the back to hang a rad externally. The top can be *heavily* modified to utilize that 230mm fan space for a 200mm rad. But really, anything you do will most likely need to be externally mounted.
Size of radd depends on your intent. OC or not, cpu only or gpu too. A 240 will do nicely for a stock or low oc cpu. If you want to add gpu, minimum 2 240 rads needed. OC? Time to look at 360 or 480 rads.
Hope this helps as a start. Give us a bit more info andd we can go from there
zander1983
424
30
+1 to Buzz247
I've also spent countless hours reading and researching and though I don't have a custom look (too expensive at the end of the day) it is "almost" not worth buying these starter kits.
If you can't afford a custom loop ($600+ minimum) stick with air or a closed loop.
If you do have the cash to splash make 200% sure you can get waterblocks for your GTX670 as it may not be a reference board etc.
Good luck :)
manofchalk
Glorious
Wouldnt say you need $600 to get a loop started, you can easily build an upgradable CPU loop for $250. Then when you need it, throw on a GPU block (~$100) and another radiator ($50 at most for a dual rad, assuming there's already a dual for the CPU). CPU + GPU loop, $400 once you account for tubing fittings and other small bits.
Buzz247
962
111
Manochalk beat me to it lol. Don't scare off the poor boy zander :p Case in point, http://www.frozencpu.com/products/17638/ex-wat-229/XSPC_Raystorm_RX240_Universal_CPU_Water_Cooling_Kit_w_D5_Variant_Pump_Included_and_Free_Dead-Water.html?tl=g30c83s137
Decent product, includes fittings, and standoffs for external mount, and a pump on res combo INSTEAD of in res. And under 300. This would suit your cpu well. And can be built off of later.
***warning: this is addictive! Manochalk was there when I began my trip at the 300 mark. It is now at a 1500 mark lmao!!! I firmly believe in overkill for cooling
Buzz247
962
111
www.coolingconfigurator.com find your card. If it lists a full cover block, voila! You have a reference card and can pick any block of reference match from any manufacturer.If it doesn't, then you can pick any universal block, and make sure you get vrm heatsinks to go with it
manofchalk
Glorious
^ I'm in the same boat (island) as you.
Just today sent the order for a 7970, water block for it, PMP-500, a reservoir plus some other watercooling bits and pieces, $720 all up. Just lucky I had a buyer already lined up for the parts I was replacing, makes this upgrade a lot easier to swallow :).
GeneralJim25
350
alright that was quite a bit read through lol i just got off work, and thought my thread was still going to be dead in the water :p but like i said, im looking for it to be upgradeable so i can tack on my EVGA GTX 670 (and a second when when i buy it) right now my computer is cooling off of an H80, which is great and all, but i want to sort of prepare for the summer and get something to cool my GPU down with too at the same time. also do plan on overclocking my cpu (which is going to be upgraded to a FX 8350). and actually that kit that one of you linked was one of my choices, just didnt feel like linking to it from my phone lol and this is my case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811517010 (i was looking at a youtube video and the dude said the case will hold up to a 360mm rad.)
also this is my GPU: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2580889, so as far as the water bock for that goes, would this work: http://www.frozencpu.com/products/16701/ex-blc-1190/XSPC_Razor_nVidia_GTX_670_Full_Coverage_VGA_Block_-_Reference_Design.html
GeneralJim25
350
ok, so unless i find out some information that makes this plan physically unfeasible, the plan is to go this route. i plan on buying this kit: http://www.frozencpu.com/products/17638/ex-wat-229/XSPC_Raystorm_RX240_Universal_CPU_Water_Cooling_Kit_w_D5_Variant_Pump_Included_and_Free_Dead-Water.html?tl=g30c83s137
a SECOND Gtx 670
2 of these for both GTX 670s: http://www.frozencpu.com/products/17638/ex-wat-229/XSPC_Raystorm_RX240_Universal_CPU_Water_Cooling_Kit_w_D5_Variant_Pump_Included_and_Free_Dead-Water.html?tl=g30c83s137
and an 850w Corsair TX 850M: http://www.frozencpu.com/products/13843/psu-494/Corsair_Enthusiast_Series_TX850M_850W_Modular_Power_Supply_-_SLI_Ready_CMPSU-850TXV2_.html
anything wrong with this setup cooling and power wise? what additional items would i need. wold the kit come with enough tubing and stuff to extend to the graphics cards? etc. i need an answer asap
Buzz247
962
111
2 concerns - I have dual sli gtx 670. These babies run warm. I would HIGHLY advise 2 360mm rads. I am on my phone atm so hard to determine if a 360 would fit well up top, but from what I can see board clearance maybe an issue on an rx rad. EX slim with pull fans may fit with minimal modding. The second rad you can hang off the back. You will need extra fittings for second rad, gpus, an sli water bridge, and extra tubing. But yes it can work. You will probably lose the top, if not top 2 drive bays when you install this.
GeneralJim25
350
my case can do 1 360mm radiator. nad then there is a fan mount spot on the back that i could a 120 or something. and then there is a spot on the bottom i could put another 120.
edit. would the slim 360 work in conjunction with a double thick 120mm Rad on the rear exhaust? and i MIGHT be able to get another double thick 120 mm rad down on the bottom as well, though the PSU wires will have a tight fit. do you thin that wuld be effective enough?
Buzz247
962
111
No it will not be. Look at manochalk photo he posted. That 120 fan spot can be used to mount a 360. A cpu and 2 gtx 670 and oc the cpu... u NEED 2 360 minimum
You don't need a whole other kit. Just an extra rad (recommend rx360 for rear mount) fitting, tubing, and extra fans. So ex360 d5 kit, and a few extras listed above
GeneralJim25
350
really? o_O if it can do this, its news to me. internal or external?
Buzz247
962
111
Both. Ex360 up top, rx360 off rear like manochalk. Kit has standoffs to do it already included.
Tubing path as follows:
Res/pump 》cpu 》top ex360 》gpu1 (sli block bridge) gpu2 》rx360 on rear 》 res
This is called a single loop setup. Most effective for your setup and most common
GeneralJim25
350
so top internally mounted and rear externally mounted. got it. should the back mounted radiator be going down with the case, or above it? i know that sounds a tad stupid :p but still, newbies should ask everything possible, cause you never know what is and isnt important XD
Buzz247
962
111
Scroll up to manochalk's post and click the project red-chalk link in his sig. Mount your rear just like his. Since your tube ports on your case are on bottom, I would suggest un mounting the rad during leak testing to be able to move it around and get air out. Otherwise, you would have to have long tube runs to mount the rad with ports on top. More tube means more flow restrictions.
GeneralJim25
350
ooooooh ok i see now. thanks. one more thing. do i NEED to install a drain? (another stupid question) and how should i go about this?
Buzz247
962
111
Lol if u keep reading his build log you'll benefit from his oops and see why the answer is a definitive yes. One of the first questions he usually asks is "how do you plan to drain" lol. A simple T line will do. Your res with that kit has a fill port built in
GeneralJim25
350
ookey dokey then :p thanks. well ill be back on here tommorrow as im setting it up (on a different computer of course) just incase i have any questions. hopefully you will all be as helpful as you were today :) and hopefully i run into no problems... XD im expending almost 1000 dollars on this in total
rubix_1011
Contributing Writer
Staff member
To address the question about 'how many/what size radiators', there is a section of the sticky that specifically covers what you will need based on your cooling needs. It might take a few times of reading through this, but it all depends on total loop TDP needed to be cooled.
Buzz247
962
111
One issue I have with that guide (although it is an excellent starting point for research and wrapping your brain around the basic concepts) is it gives some false impressions of baseline. For example, it estimates the RX360 to handle 675w. That would be capable of 2 gpu (310) and a base OC cpu (135w). Reality is... a big hell no. Zero headroom, no mention of accounting for environment factors (ambient temp, relative humidity), no accounting for static pressure vs cfm fan choice, and certainly doesn't address possible issues with someone just headed into world of OC. Could it do it? Probably. .. wirh perfectly matched fan setup running full blast and pump humming at max - damn jet engine lol. But a tenant of most watercoolers is balancing performance and noise. Adding an extra rad allows lower pump and fan speed thus quieter. Plus more headroom for oh crap moments. Rule of thumb i read, and seems to hold well, 1.5-2x 120mm per component cooled. Unless I missed these things somewhere, really should be added
Buzz247
962
111
I have yet to see one of these that actually has numbers that stand up to testing. But get back to me in a few months... the GF wants to cool her new build with a bong attempt
Buzz247
962
111
quotemsg]
They work..res water is constantly 6-11c below ambient.I've been running one for almost 2 yrs now.[/quotemsg]
At idle? Full constant load? 6F sure I've seen that under load. 6-11C?? Um... thats huge delta! Would require at least an 8ft tower at 1500Lph
But hey, it's why I agreed to help her try one. Aside from fudgy math trying to be met out, I gotta figure out how not to make it look so damn ghettofied lmao
Similar threads
