First Watercooling loop
abyssbreak
125
About to build my first custom loop. I've done alot of research and have been considering this for quite some time. However since it is my first loop I want to get someone elses opinion and make sure i have everything i need to do this properly. Here's my cart from frozencpu.com and i will list what i plan to do with this as well. If there is anything I am missing or if anyone has any better suggestions please feel free to give feedback.
http://i.imgur.com/We3iyGq.jpg
i am using the cooler master Cosmos II case. the triple 120mm fan will be top mounted with 3 of these fans in pull config and 2 in push. only 2 because a third would cover my cpu 6pin port. the 140mm rad will be rear mounted with the stock case fan to push air out.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181040
i will use the quick disconnect and t splitter to run a drain line out the back of the case should i have to drain the loop someday.
Yes it will work, can you please put the names of the components directly into your post next time? It really helps us; thanks :) Also, I recommend an XSPC AX series radiator, as they are excellent for the money but other than that, its perfect.
