Ok so nothing was powering on when i pressed the power button so i did the paper clip thing and my case fans turned on... but when i plugged it into my motherboard nothing powered on... help?
Ohhhh wait the power switch connector i think i plugged it wrong but i have no idea how to plug it in cant find it in manual... i have the b350 tomahawk
Thats not the connector I mean (and 1 inactive pin connection is normal, btw). I'm talking about the connectors for the tower...there'll be a Power Switch, a Reset Switch, HDD Activity Light, etc that all connect to the motherboard.
