Hi, not sure if this is correct section for my problem?
I have purchased three :
Fractal Design Prisma AL-14 – 140mm Silent computer Fan - PWM Control - Six LEDs - ARGB - Optimized For Silent Computing - High Airflow - LLS Bearings - TripWire Technology - RGB (3-pack)
I need to fit them onto my:
Gigabyte Z390 GAMING X (rev. 1.0) Motherboard.
I have attached the fans onto the case but cant connect the rgb cables as the Motherboard only has 1 4pin led/rgb header ( 12volt) and the fans are 5v???
Any advice please if you can help.
