fit a liquid cooling in my pc
bfcallan
170
23
"Supports Liquid Cooling No"
Thats from the informational page on the tower on Mars Gaming's website.
There aren't many pictures of the tower that I can find but, you would not be able to install the radiator on the back of the machine. If you were to install it looks like it would have to be on the front where that front fan is. Even still I am unsure if that would work. You can always make a return (depending on where you purchased) if it does not end up fitting.
Sep 28, 2018
My tower is a mars gaming Mc416 and my processor is an amd fx 4300.The problem is that i dont know if the radiator is gonna fit in because he has a hollow for a 120mm fan but the power supply its very closer i dont know if hes gonna fit
bfcallan
170
23
