Question Fitment problem with LED connector
pikeman666
19
I’m building a system with the ASRock Steel Legend X670e. The led connector on my Corsair H100 isn’t securing to the 3-pin header on the MB. It fell off while I carried the PC from my bench to the desk! I had it correctly aligned, but there was no obvious resistance when I pushed it down. I have not used a MB with LED features before. None of the other headers have the issue, they’re the legacy inlines and snug up nicely. This seems like a peculiar design. . .
Whats going on here? I don’t want to put too much force on this and really should not have to.
Thanks!
Are you referring to the ARGB LED connector?
https://assets.corsair.com/image/u...p to the ADD_LED1 header on the motherboard.
Yes, That's the one. I know there ...at's tighter and coil the extra wire. Thanks!
