[SOLVED] Fitting Focus gold 650w PSU into Corsair 750r airflow case
Jun 6, 2020
The PSU comes with a mounting bracket, but for the life of me can not figure out how to attach it to the case.
DSzymborski
Curmudgeon Pursuivant
Nor does the SeaSonic manual appear to note any special PSU bracket and I see nothing in the included parts. It's literally just "stick it in the PSU area and put in four screws."
I think you're going to need to link to a picture of what you're looking at. Or a better description of what you're looking at.
The correct case would be helpful as well; are you sure this bracket you're referring to isn't a PSU shroud? It's very important to be specific on model numbers and this is just one of many reasons; precision is extremely important in this hobby.
