Fix for mic static noise?
SirRadget1995
12
I have a Cisno Bm800 Condenser Microphone.
I also have a Innogear 1- Channel 48V Phantom Power Supply to go with it.
Roughly $80 for everything.
Only problem is THE STATIC.
Here is what I've come across so far.
When you change your format in your recordings section to CD Quality, it sounds like an absolute potato. With mic boost off there is no static. With it on, there is a small amount.
Though when I change my Format to Studio Quality, it sounds absolutely fantastic. 96000 Hz or 192000 Hz, sounds great. The problem is there is so much static, even with mic boost off.
THERE IS TONS OF IT.
I have my stuff updated and everything, I am just confused as to why I am getting this static. Anyone know of how to fix this?
Its plugged in the back and yes I have a pop filter
