Fix glossy bezel on xb270ha monitor
Thirall
186
I bought a new xb270ha monitor, and it works great. The only problem is that the bezel has a glossy finish, and that glossy finish reflects the screen a bit. Giving the illusion that there is a black line and at the top, bottom and sides, between the end of the screen. Although I know it isn't a black line since I tested it putting my mouse close, and it reflected it, so that there looked to be 2 mouses.
Anyone got any suggestions on something I could do to "fix" it? I want a solution that won't void my warranty. Perhaps some matte black self adhesive vinyl?
http://www.amazon.com/Permanent-Adhesive-Backed-Vinyl-Ease-V0403/dp/B00331SX7U
Although it says permanent, does this mean that it will be super hard to get it off the bezel if I put it on wrong?
Or matte black washi tape, but I do not know how I would use that since it is a roll:
http://www.amazon.co.uk/Washi-Masking-Tape-Roll-Matte/dp/B00GWVNSI2
But can't I use vinyl self adhesive tape? Another user on another forum I asked at said that was the only option..
Is vinyl self adhesive tape removable (may seem like a dumb question) since it said permanent on amazon?
