I had to replace my z490 Carbon Wifi after a power fluctuation event, but now I am continuously getting an error when trying to fix my RAID setup.
I have 2 RAID (mirror) volumes set up:
- Samsung 870 EVO (SATA), works fine
- Samsung 970 Evo Plus (m2), works fine with only one M2 plugged in.
If I plug in the 2nd drive in the m2 socket, the problems appear. I am getting an error at boot saying M2 Genie error, Press F1
What I tried so far w/o any success:
- Updated BIOS to the latest
- Unplugged all the SATA drives
- Tried to switch the SATA Mode to AHCI but after reboot they are switched back to [RAID/Optane Mode]
- Messing arround with the M2 RST PCIE Remapping but, again, the settings get reverted after reboot
- Intel RST shows my RAID volume as degraded (which is obvious) and 1 NON-RAID physical disk which is the new M2
I want to be able to add the new M2 in the RAID volume and then sync it but I'm not seeing any option, or I'm missing something in the manual
Thanks for all your help.
