Hi there,
After having a smooth oc of 4.6 ghz for a while (a year maybe longer?) on my 6600k (with the msi pc mate motherboard) I decided I should try changing the base clock to go a little higher. For some reason now when I try to go back to the former 4.6 ghz, the actual clockspeed is always 10 to 15 mhz lower than the fixed clock that I entered. It reads 4.585 for example. The same happens when I try a clockspeed of 4.5. Then it reads around 4.490.
When I try to compensate by setting the baseclock to 101 instead of 100 it doesn't really change anything. I've checked the powerlimits a hundred times and it is really anoying.
Any suggestions would be most welcome! Thanks in advance!
(Oh and the clocks were measured with cpu-z and aida64)
specs:
msi z170a pc mate
skylake 6600k
noctua nhd fantastic fabulous cooler
r9 r390
specs:
msi z170a pc mate
skylake 6600k
r9 r390
