Recently built my girlfriend a PC using some of my old parts only to find out at the end that the Power SW pin is bent and not working. I have another compatible motherboard, but it's major overkill for her use case and I'd rather use the one currently in the system. Are there any relatively easy fixes/work arounds for this?
If it's something that would end up being a soldering job then I'll probably replace the motherboard and maybe use the broken board as a longer term project to learn some new skills. Either way any solutions would be much appreciated!
