K kikidee19 Prominent Dec 5, 2017 1 0 510 Dec 5, 2017 #1 Toshiba satellite pro when I go to shut it off i get message that says Toshiba flash cards preventing shut down can u help please I have to click shut down anyway
Solution Barty1884 Dec 5, 2017 Does the Toshiba FlashCards application show in your startup tab? On Windows10, open task manager and look under "startup". If it's there, disable it. On Windows7 open MSConfig and then "startup".
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 Dec 5, 2017 Solution #2 Does the Toshiba FlashCards application show in your startup tab? On Windows10, open task manager and look under "startup". If it's there, disable it. On Windows7 open MSConfig and then "startup". Upvote 0 Downvote Solution
RememberThe5th Illustrious Jul 30, 2014 6,995 170 41,140 Dec 5, 2017 #3 Its just closing the program of the Flash card. Upvote 0 Downvote
J jasonleebell.jb Sep 2, 2018 3 0 10 Sep 2, 2018 #4 Barty1884 : Does the Toshiba FlashCards application show in your startup tab? On Windows10, open task manager and look under "startup". If it's there, disable it. On Windows7 open MSConfig and then "startup". Same problem here, but no flash cards to be found in task manager Upvote 0 Downvote
