Flash Drive not being detected!
kushalsv
5
Hi guys, I have a Transcend 8GB Flash drive (http://img.dxcdn.com/productimages/sku_152304_4.jpg) I'm running Win8.1 x64. The flash drive had bootable Win7 on it, I used Rufus to format it. Now, my problem -- I accidentally plugged out the said flash flash drive when I was deleting its contents and now it isn't working!
I can hear the sound when its being plugged it, but its not visible in My PC. This is how it looks like in Device Management > Storage -- (http://i.imgur.com/G9l9tXJ.jpg). I can see it in Storage, but not in PC. I think it's seen in Device Manager too -- (http://i.imgur.com/GL8wL1l.jpg). I tried Cleaning it in CMD too, But -- (http://i.imgur.com/SpXNFPO.jpg).
Now the bizarre thing, This flash drive is working normally on other computers! I've tried 3 different PC's and it works fine! It isn't working in mine! What do I do? Please help me through this!
If the situation is that bad, then the last resort will be to format the OS. After a fresh install of OS the PD will work as nothing happened ever. Good luck.
It didnt work on safe mode either.
Uninstalling driver and the device didnt work either.
Please any other suggestions? I'm breaking my head over this damned flash drive!
I got a solution i had the same problem with my transcend 700 series 32gb 3.0 so i did is visited http://www.transcend-info.com/Support/Software-3/ and downloaded the software n it solved my problem. Hope this helps you.
