I used the memtest86 for the first time yesterday and after using it i decided to get rid of it , if you have not used this program you wont know you have to install it onto a flash drive then run it from the boot menu to make it work.
I went to the my pc where the drives are shown and that particular flash drive has now split itself into 2 separate ones , one has the original drive letter H and the other one is shown a I.
I dont know what to do so that it goes back to how it was ...... H with no I
tried this article but when i did list disk it does not show the flash drive i am looking for
www.partitionwizard.com
Flash Drive Showing up as 2 Drives [Quick Fix] - MiniTool Partition Wizard
What can you do to fix the flash drive showing up as 2 drives issue? This post illustrates 2 effective methods. You can have a try!
