Flash drive won't format
litefoot
I have a problem formatting a USB HP 8GB drive. I've examined many solutions on here and other forums but none of the solutions listed work.
When I plug in the USB drive I'm immediately prompted to format the drive, but when I click OK, it doesn't work. I go into disk management and try the same but I get the below error. It's drive G by the way.
FileDownloadHandler.ashx
I've also tried following a suggestion to use 'clean' on CMD but that doesn't work either (See below screenshot). Any suggestions?
Here's the result:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Andrew>format g: /x /q
Insert new disk for drive G:
and press ENTER when ready...
The type of the file system is RAW.
The new file system is FAT32.
QuickFormatting 7827M
Cannot determine the number of sectors on this volume.
Link
Use Hp format tool for this stick.. it seems the drive has some protection which can be unlocked using this software or tricking registry.
Ok, this is what happens:
