Flashpoint GOTY & WWII doesn't work with Radeon 9800 PRO
G
Guest
Guest
Archived from groups: alt.games.operation-flashpoint (More info?)
Hello NG,
a Friend has the following Prob:
He install his OPF Goty ..the Game was able to run correctly.
He install the DXDll1.0 plugin (for improve Graphics)
...and the Game work correct.
But if he install the WWII upgrade
(+200 MB Objects update + 10 MB Patch)
the Game will shutdown on Start with the Error
D3D Error - Out of Memory.
He has a Radeon 9800 Pro 128 MB + AMD XP 1 GHZ
and a fresh installed WIN XP Prof. SP2 with DirectX 9C installed.
(newest ATI Drivers also installed)
He remove the DXDLL1.0 plugin and start the Game without it,
but the Error persistent exists.
The other Mods Resistance, Red Hammer or BTL work properly.
(also with DXDll1.0)
Does anybody know this Mistake and can help ?
greets Jeff
PS: sry 4 my bad english,i am German *g*
Try adding -nomap to the shortcut target line. it should look
something similar to this:
"C:\Program Files\Codemasters\OperationFlashpoint\FLASHPOINTBETA.EXE"
-nomap
that might help.
Check graphics settings between desktop and ofp. Ensure resolution and
colour depth are not the same.
80% sure this will fix.
Liddle Feesh
*fap fap fap fap*
-nomap -nosplash
those should be so standard by now
this guy should have been able to tell his friend this
"[RM]Wolfy" <thenomeaningnofx@hotmail.com> wrote in message
news:a3336775.0410080525.4021f271@posting.google.com...
> -nomap
> that might help.
