Flow of my pump is going really slow
Unscrew the top of the reservoir slightly while it's running. Also try tilting it around a little bit (with the cap on) to dislodge any air bubbles that may be trapped.
Yeah, it worked... THANK YOU VERY MUCH 😀
You're most welcome.
If I may say so, those fittings are sexy. You've done an excellent job.
Down the road you may wish to swap out that AIO cooler with a waterblock and add your CPU to the loop. A well constructed custom loop with a triple rad can easily cool a high end GPU and CPU.
