I built a system sometime ago and recently added a sensor to detect temp and flowrate thats made by tt, have xspc d5 170 combo, from the pump to cpu block hard rube about 2.5ft long with 2 90 bends then a ft long tube to 360 rad above with 2 90 bends and then to gpu block and it is ft long with 2 90 bends and to another 360 rad above and it is ft long tube and then 280 rad below with 4ft long tube with sensor in between to a T fitting and it has 3 90 bends apart from T fitting and then 1.5ft long tube with 2 90 bends to reservoir, now this pump is rated at 1200lph flowrate but i am getting only 130lph and my loop seems to restrict flow by 90%, i have 7900x ocd to 5ghz and a 2080ti ocd to 2000mhz so my hardware needs lot of cooling and i have a very big case where my mobo asus x 299 apex lays flat on tray parallel to floor, i wanted 2 rads to exhaust hit air and the bottom rad to provide cool air into frame along with front 300mm fan also pushing in cold air and the top 2 rads have 6 fans with push pull to remove have better, at this point i believe flow rate is limiting my cooling performance, how can i improve flow rate, thanks.
