Hi have two GTX 760s in SLI. Work great, fans are working fine, temps are fine. However while under load they start to make a fluttering sound. It is the best word I can use to describe it. I tested every other fan in my system individually, and no sound. I turned the GPU fans to Max while nothing was running and I get no sound. But while under heavy load, a fluttering sound comes from the GPU area. Is this normal/okay? Any fixes? Will it damaged my cards/machine?
