Fonts in NFS Underground not displaying correctly
G
Guest
Guest
Archived from groups: alt.games.need-for-speed (More info?)
I just installed NFS Underground, only to find that the fonts on the Main
Menu (after the initial videos finish playing) are completely illegible. All
that I can see is boxes where the text should be. Is there any way to fix
this... hopefully without re-installing? *crosses fingers*
Turn up ansiotrophic settings on your video card driver.
"Jeff Reid" <noone@nospam.com> wrote in message
news:yfuFc.12129$z81.10781@fed1read01...
Main
All
fix
> That's a big word! 😉
I just assumed that a required font(s) were not installed. Why would the
Anisotropic settings have anything to do with it? *me scratches head*
Either way, I'm looking up that big word you just said in case that's the
solution :)
Because the text is implemented with some 3d aspects affected by the
ansiotropic filtering.
All
What graphics card do you have? I had all sorts of problems on an old
Geforce card that only had 32Mb od RAM on board. Once swapped to a 64Mb card
it was all OK.
Adam S
card
> it was all OK.
> Adam S
> Yeah, mine's only 32MB 🙁
I think it's time for an upgrade... or an entirely new computer.
"Scu" <nospam@nospam.com> wrote in message
news😱2bGc.79343$sj4.65684@news-server.bigpond.net.au...
> card
> > it was all OK.
> > Adam S
There should be a 'ReadMe.txt' file in the support folder of where the game
is installed on your PC, this give lots of info on graphic cards and known
problems.
I have NFSU running quite happly on an AMD 1300MHz Duron, with 512MB ram and
an old Sparkle Geforce 3 Ti200 64Mb graphics card, most of the graphic
options are there (except crowds) and that card is only DirectX8, so you may
not need to get a completly new PC, but is is a good excuse 🙂
Adam S
