[SOLVED] For my case, which will be better? Intake or Exhaust?
Jul 9, 2021
4
My case have 1 rear slot(80mm), 1 side slot(120mm), and 2 front slot(80mm). I already have 1 rear slot as Exhaust (80mm) and 1 side slot as Intake (120mm). I want to buy another 2 fans (80mm) for my front. Should the 2 front fans intake, while the side and rear are exhaust?
Micro-ATX Case
In case of a M-ATX case, the side fan might interfere with the CPU fan, reducing its efficiency, so you'd rather have an exhaust side fan, or not at all.
Two intake front fans and an exhaust rear fan is the most common setup for your case.
Hello, I have Ryzen 3 3100, GT 1030, and Micro-ATX MOBO and Micro-ATX CASE. I have 1 in rear (80mm as exhaust), 1 in side panel (120mm as exhaust), and 1 front (120mm as intake). I lived in PH so sometimes it gets hot quickly. Should I change anything?
those are all low-power devices so computer fan configuration doesn't matter real much. although personally I'd configure al fans as intake and put filters over everything, I'm not a fan of dust.
Also is the 3100 is using the cooler that came with it?
