Formating/System reserve
rcaladlr
37
hello,
I recently built a new comp and installed everything on a 1tb internal hard drive. Now that I have succesfully installed a SSD and got it working, I still want to use my HDD as storage.
I already formatted the partition of 931GB there is a partition of "System Reserve" of 70 GB. Should I format that as well and how would I get the whole 1TB back?
NO, do not play around with the system reserve if you do not want to crach your installed system. The OS uses the System reserve and if you format it you will have to do a fresh install.
931 GB (+ 70 GB) is 1 TB. You can affod to lose 7% to slack. In any case the slack on a HDD depends on the sector size and losing under 10% is normal.
