Formatted hard drive, lost everything! Please help!
Arlen10
401
Hello,
Before I explain, please understand I am using a 240gb SSD as my bootable drive with Windows 10, and a 1TB HDD that stores all my data.
I recently encountered an issue with Windows 10 where it would not load, went through all the troubleshooting methods I could do, whatever, so I formatted my SSD (which is fine, no data I need is on there), and reinstalled Windows 10. I wanted to delete all extra partitions that I didn't need, so I removed all the ones associated with the SSD, and a 499mb partition that was associated with my 1TB drive. The 499mb partition was something else, it doesn't have the data I need.
So I installed Windows 10, set up everything, all good, but I noticed the 499mb partition was active and wanted to extend it on my 1TB drive. I went to disk management and attempted such, but I could not do so without deleting the partition. So I made sure I selected the right one (the 499mb partition), deleted, and boom, whole disk was deleted. My mistake, I should have paid attention to what I was doing. But now I've lost everything that is important, thousands of hours of work, and all my images and videos from my trips among other things.
What makes matters worse is that I freaked out, and reinitialized the drive. I realize now that this could have affected the data. And since I had setup Windows to write my Desktop, Documents, Downloads folder, to the 1TB hdd, it wrote over about 10mb of data automatically. I stopped and undid everything in Windows and removed all write permissions to the hard drive for all users.
I figured this wouldn't be too hard to recover, what matters most is that I can get the core files back related to work and my trips. I used EaseUS Recovery software to attempt this, (as well as some other software but this is the one I actually used to run the whole thing). It built the directories and all that, it looks good, but the only things that come up are my past systems on this hard drive. I had Windows 7 and Windows 8 on it previously. I cannot find my data for my current Windows 10 system. I'm still looking through this as there is a lot of data, but now I'm running Unformat on the system, but I'm not sure what else to do if this doesn't work. I could take it to a recovery professional, but I don't have too much money to get this done right. I'm a student right now but I have some clients I provide computer services for (lol) and another job at a small company part time.
So this leads me to my question. How can I recover my data most effectively? Is there any software that I can use that can recover data from my most recent OS? Although initializing the drive and writing a small amount of data to it could affect my data, I should be able to recover everything mostly? Right? Is there a way to recover the data from this drive while keeping the directories intact? Any sort of assistance with pointing me in the right direction would be appreciated. The data on this hard drive is very important. I plan to take greater measures to prevent this from happening again using backups.
Here are some images below. The "cannot read" sectors that unformat is showing is very concerning. Also the EaseUS is shows about 6TB of recoverable data. I believe the raw files folder is the reason for this as it's just the same thing but without directories included. Also when recovering data, most of it was corrupted or could not be opened in Windows. This was data from partition 1.
EaseUS:
Unformat Part 1:
Unformat Part 2:
Unformat Part 3:
Again I'm not sure what the best way is to recover this data. It seems like it should be easy but so far it has proven otherwise.
Thank you for any help.
There are a few different programs that have their own layout and style, but long story short none of it is going to be perfectly laid out and easy to recover. Fire recovery just doesn't work that way. When you clear a drive, you remove the file system and the drive completely forgets where that data is stored. It might be able to pick up and recognize files from other files, but it typically ends up mixing a lot of files together in large folders as it doesn't know where they were originally located.
I'd recommend telling it to recover all of the files to a separate drive, and then searching through it using Windows search feature and manually deleting file you don't need as you go.
To avoid this in future, you should develop a...
Okay. Unformat completed, I do not see my files anywhere.
The directories should look something like this:
*Windows/
/Desktop
/Downloads
/Documents
/Pictures
/Videos
/Music
/Program Files
/Program Files (x86)
*Dropbox/
*Intel/
And some other folders. I checked every single partition. It looks like after I initialized the drive after deleting it, it made the 931.39GB labeled New Volume as that's what it is currently labeled as. Before it was formatted, I was pretty sure I called it 1TB HDD, but it could be Local Disk.
Pictures below:
So a couple of things... That 499mb partition were these GPT disks or MBR disks? If it was GPT that is there for a reason, and deleting it was your main issue. If the drive was MBR, you probably deleted that too somehow.
Now if you had tried to recover the drive from there you may have been ok, but when you reinitialized it you killed any partition table it may have had and overwrote it.
The reason you are seeing only old stuff is thats the stuff that was never overwritten. Thats not to say it can't be saved, I've seen miracles happen, but you've made it much harder.
I've never used it but I heard this software is good. The demo will at least show you if it COULD save your files, then you know its worth buying:
http://www.runtime.org/
This is also worth a try and free:
http://www.piriform.com/recuva
Good luck, you are going to need it, I'm sorry.
WHAT!? You have "clients" you are providing computer services to? I hope it's a dust cleaning service that you're providing them! You know, something that don't actually require you to turn their PCs on! Just kidding- don't hunt me down and kill me! :)
Kidding aside, I feel your pain. I've been there and done that myself. I've had pretty good results using Recuva in the past. Just DO NOT INSTALL OR SAVE ANYTHING TO THAT DRIVE until you have exhausted all attempts at recovering your data. There's a good chance you can recover most of the files, you just may end up having to try several different programs. Also, search Youtube for videos on recovering data, may find something helpful there.
I know exactly how you feel right now, best of luck recovering those files.
Yeah the clients I have a more of contacts that come to me on a frequent basis for certain solutions. When it comes to other peoples hardware/software I am a lot more careful. Thank you for your suggestions. I'll try out Recuva next.
Thank you for your suggestions. It is MBR I'm pretty sure. I'm attempting to find the data I once had using EaseUS, going to try Recuva next.
To avoid this in future, you should develop a backup solution, either a networked system, or an online service like Google Drive.
