Hey guys!
I've been searching online for hours without finding a solution so here I am; google (or my common sense) has failed me.
I bought a 500GB portable hard drive yesterday hoping to use it with my car radio, which supports it. Now here's the cool part : The Iomega Prestige drive that I got natively protects the drive with AES 256-bit, so the radio couldn't detect it, as it usually boots a Virtual CD into windows as if it were firmware. I contacted Iomega, and they told me that the new version of their encryption firmware/software has the option to remove the protection without ruining the drive.
So I manage to update the damn thing, and remove the virtual CD.
My radio obviously does not have a windows file system so the only format that makes sense using is FAT32. Before removing the Virtual CD, I could format the 500GB to FAT32 without any issues (using third-party software). Now, not only is exFAT not available in the Windows formatting tool (which would worthless anyway), every software I've tried cannot detect the external hard drive which is in NTFS.
This is first time I've seen a drive that cannot be formatted to another format so I am completely lost. What could cause this? How can I format it? Some posts on other forums recommended using XP to see if the options are diffrent, so I'm currently installing an XP Virtual Machine to see if it works.
So what's going on? Thank you for enlightening me!
Patrick
Patrick
back to troubleshooting it is
