A great addition to the game, Launchpad is indeed an item that can give you a lot of benefits and help you create a foolproof strategy if utilized in a proper way. You can use the tricks mentioned below to properly use the launch pad:
Avoid Trees and Buildings:
One thing that you need to keep in mind while placing the launch pad is to avoid places trees and buildings or other structures that can block your way. It is imperative to place it in an open area. The reason is that the launch pad shoots you into the air in a certain trajectory and if there are trees and buildings near you, you can get stuck in them and that will waste your Launchpad. Keep in mind that you cannot pick up a Launchpad once it is placed on the ground.
Build it at a Height:
The one major drawback that Launchpad has is that it does not shoot you very high in the air. Although it’s named as launch pad but it does not launch that high. Therefore, if you want to go higher with the use of launch pad either to reach somewhere or to use your glider, then you need to place your launch pad someplace that is already at a certain height like mountains, building tops, and towers etc. Moreover, you can build some high structure and then launch yourself from there as well.
Get in Opponent’s Base:
One of the best thing that you can do with the help of a launch pad is to use it to get into the base of the opponent. Suppose your opponent has created a large base and if you build your way up there, you will be seen so you can launch yourself with launch pad and then use the glider to reach opponent’s base quietly.
Use it To Get to Cover:
Another benefit of using a launch pad is that you can always get out of hostile situations where you are certain that you will get killed if you move a bit. You can immediately place the launch pad at the place where you are standing and quickly launch yourself from there to a place where you can get cover like in trees or a building etc.
Combine Hop Rocks With It:
A secret that most of the people don’t know about the Hop Rocks is that it can perform exceptionally well if combined with the launch pad. All you need to do is to consume a hop rock and then place a launch pad before you run out of the aura of hop rock and then launch yourself from the launch pad. You will go much higher this way.
These are all the things that you can do to use launch pads properly. Just make sure that you follow all of the tricks mentioned above and you will be able to use it to surprise your enemies or to get out of tricky situations.
![aLt7PPB.png](https://i.imgur.com/aLt7PPB.png)
![alfJprY.png](https://i.imgur.com/alfJprY.png)
![7xHaxVa.png](https://i.imgur.com/7xHaxVa.png)
![Fuk5VVf.png](https://i.imgur.com/Fuk5VVf.png)
