Fortnite Crash help
deadfreyya
45
When im playing Fornite about 1-2mins its crashing.Firstly my monitor freezes then monitor goes black (2-5sec) after that monitor turning on and i getting crash message.
Sometimes its crashing when im in menu. Video drivers are up to date
My pc specs:
gpu - radeon rx 560 4gb
ram - 2x4gb ram 3100 mhz lpx vengeance
cpu - ryzen1500x
mobo - b350 tomahawk arctic
psu - VS650 Corsair
Fortnite is high cpu torture. Do you have the cpu OC? If not, you might want to apply some because it's possible that high ram usage from games like that might be creating instability with ram speeds at 3100. You could also try backing down on ram speed to 2666MHz and see if that helps. (temporary). If it does, then a small OC bump should cure that.
Also turn off Xbox DVR stuff and any game-bar usage.
