popatim :
These are what is supported by the socket.
What Toshiba has not locked out in the bios is another matter. I see no posts of anyone upgrading the cpu in this laptop and honestly, with the 4910mq being the best one you could get (without needing a better cooler) only producing 200mhz more - its understandable. 200mhz isn't very noticeable from a users perspective.
Thanks for the reply! How did you come up with 200 MHz if you don't mind me asking?
- Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
- Intel(R) Core(TM) i7-4910MQ CPU @ 2.90GHz
Wouldn't the difference be 500 MHz? (2.90 - 2.40)
Here are some benchmark comparisons from
UserBenchmark.com
Intel Core i7-4700MQ vs Core i7-4910MQ
Userbenchmark Effective CPU Speed: 59.7% vs 66.4%
Intel Core i7-4700MQ - 226th / 1102
Intel Core i7-4910MQ - 169th / 1102
Also, at what point do you start to see a real difference as a user? This reasearch all started when my son was trying to play Fortnite on my PC and that is when I noticed the obvious issues it had handling the game. Here are some requirements from the Epic Games site on the game.
What are Fortnite's minimum and recommended specifications?
Last Updated: Sep 10, 2017 05:10PM EDT
Our recommended PC specifications for Fortnite Early Access are below. As we go through Early Access, these minimum requirements will change to include more hardware options. If your system does not meet these requirements, be sure to check back as we improve our optimization.
Recommended System Requirements:
- Nvidia GTX 660 or AMD Radeon HD 7870 equivalent DX11 GPU
- 2 GB VRAM
- Core i5 2.8 GHz
- 8 GB RAM
- Windows 7/8/10 64-bit
Minimum System Requirements:
- Intel HD 4000
- Core i3 2.4 GHz
- 4 GB RAM
- Windows 7/8/10 64-bit + Mac OSX Sierra
Do you have any thoughts on making my current PC capable of playing a game of this caliber with a better user experience? I'd hate to get a new PC for gaming but if I have to do so, I may do that for his birthday by getting a desktop that is easier to customize/upgrade.
Here is the link to my PC's specs.
Toshiba Satellite S75t-A7349
I have upgraded the following:
- Hard Drive:
Crucial MX300 1TB 3D NAND SATA 2.5 Inch Internal SSD - CT1050MX300SSD1
- RAM: (2 x 8GB = 16GB)
Samsung M471B1G73BH0-YK0
Thanks for all of your help.
