[SOLVED] Fortran compiler not running
niwaz_malik
25
Hi guys,
I am not really all that familiar with programming, but I do know how to get up and running on a Linux desktop machine. My question is once I have installed a Fortran compiler how to I get up an running. I mean how does one ask the computer to open a text editor, to write the program on, and then ask
the computer to compile it.
For example on the Linux machine. I write
nedit filename.f90 (provided the file has already ben created. I am not sure how to do so if it hasn't. )
then I write my program and save
type in the terminal
gfortran filename.f90 to compile
press enter
type ./a.out to run
Sorry if this is a really easy question, but I am not really very confident when it comes to dealing with computers
ijack is absolutely right.....but here something more complex.....easy.....
Carbon Emacs supports fortran syntax highlighting and compilation to a certain point.... Use text editor and terminal......from ijack links..... CarbonE (i use it and it works well / better than others ).....
Also you should think of enabling virtualization if your cpu supports it....
