B Barelylivin420 Commendable Jun 23, 2016 5 0 1,510 Jun 23, 2016 #1 Found laptop. Is it worth fixing?
Solution USAFRet Jun 23, 2016 Barelylivin420 : This is a college town with a high turnover rate. Just hoping maybe it was an easy fix that would cost less than a new laptop would It's a 6 year old low end laptop with unknown problems. Any $325 laptop you would buy today would crush it for performance, and be cheaper.
USAFRet Titan Moderator Mar 16, 2013 176,425 20,368 184,590 Jun 23, 2016 #2 Barelylivin420 : Found laptop. Is it worth fixing? Given the plethora of information you've given us, all we might say is: "Probably not." Upvote 0 Downvote
B Barelylivin420 Commendable Jun 23, 2016 5 0 1,510 Jun 23, 2016 #3 USAFRet : Barelylivin420 : Found laptop. Is it worth fixing? Given the plethora of information you've given us, all we might say is: "Probably not." Upvote 0 Downvote
B Barelylivin420 Commendable Jun 23, 2016 5 0 1,510 Jun 23, 2016 #4 It is an acer aspire 5552. The battery light blinks briefly and that's only if it's plugged in. It has no hard drive. Anything else I don't know Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 176,425 20,368 184,590 Jun 23, 2016 #5 Barelylivin420 : It is an acer aspire 5552. The battery light blinks briefly and that's only if it's plugged in. It has no hard drive. Anything else I don't know The Acer Aspire 5552 covered several different configs. All old. http://www.notebookcheck.net/Acer-Aspire-5552-Series.47033.0.html http://www.cnet.com/products/acer-aspire-5552-7803-15-6-phenom-ii-n970-4-gb-ram-640-gb-hdd/specs/ It was in the trash for a reason. Upvote 0 Downvote
B Barelylivin420 Commendable Jun 23, 2016 5 0 1,510 Jun 23, 2016 #6 USAFRet : Barelylivin420 : It is an acer aspire 5552. The battery light blinks briefly and that's only if it's plugged in. It has no hard drive. Anything else I don't know The Acer Aspire 5552 covered several different configs. All old. http://www.notebookcheck.net/Acer-Aspire-5552-Series.47033.0.html http://www.cnet.com/products/acer-aspire-5552-7803-15-6-phenom-ii-n970-4-gb-ram-640-gb-hdd/specs/ It was in the trash for a reason. Upvote 0 Downvote
B Barelylivin420 Commendable Jun 23, 2016 5 0 1,510 Jun 23, 2016 #7 This is a college town with a high turnover rate. Just hoping maybe it was an easy fix that would cost less than a new laptop would Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 176,425 20,368 184,590 Jun 23, 2016 Solution #8 Barelylivin420 : This is a college town with a high turnover rate. Just hoping maybe it was an easy fix that would cost less than a new laptop would It's a 6 year old low end laptop with unknown problems. Any $325 laptop you would buy today would crush it for performance, and be cheaper. Upvote 0 Downvote Solution
ScrewySqrl Champion Aug 2, 2010 11,199 232 53,540 Jun 23, 2016 #9 6 years old if its the NEWEST design. given it has Athlon II and 1st Gen i3 options, its likely to be more like 9 years old. Upvote 0 Downvote
Rogue Leader It's a trap! Moderator Dec 22, 2014 33,089 3,057 116,640 Jun 23, 2016 #10 If you're fixin' to use it as a door stop, sure. Upvote 1 Downvote
