Hello!
I have Windows 10 Pro 64Bit, and it is an Upgrade from Windows 7.
I've been using it since last winter, and everything worked perfect! Until two weeks ago... 🙁((((((
Almost two weeks ago Windows made some updates to itself:
- 2017-07 Security Update for Adobe Flash Player for Windows 10 Version 1703 for x64-based Systems (KB4025376)
- 2017-07 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4025342)
I don't remember doing anything else(nor software nor hardware) at that time, so I don't even know what to troubleshoot for. :|
I don't know if it's directly the update's fault or not, but it was arround that time, when the problem started...
After these updates, my PC DOESN'T shut down, NOR restart anymore. It just freezes/stays in the bluescreen with "shutting down/restarting" message... I left the PC until morning and still nothing.
And the only way to reboot or shut down, is to press the physical power and reset buttons on the case. 🙁(
I TRIED ALL THE FOLLOWING:
1. Clean Startup boot.
2. Booted in Safe Mode.
3. Reset BIOS/UEFI settings.
4. Checked RAM sticks.
5. Checked PSU(with another PSU).
6. Checked system files with "sfc /scannow" in Command Prompt.
7. Ran a freaking "Scan Disk".
8. Checked and repaired Registry entries with CCleaner.
9. Tried restarting/shuting down while holding down the Shift key(a stupid recommendation).
10. Tried a Repair with a Windows Installation Disk. It said "it could not fix any system files"....... Does that mean they weren't broken, or just too broken to even be fixed??
11. Checked the settings in the Power Options. Just reset them a couple of times...
12. Someone else with the exact same problem, even tried a CLEAN INSTALL, and still didn't help. Windows would just install again those BAD SYSTEM UPDATES. 🙁(((((
NONE OF THIS WORKS!!! So why do people keep telling me to do them??? 1 + 1 will always equal 2 !!
I don't understand this at all, for half a year it worked flawlessly! I would understand if this would happen exactly after a fresh Windows install... But not after 7+ months!!
If someone had this exact problem and managed to fix it, PLEASE teach me how you did it! I really don't want a failed fresh install................... 🙁(
My PC:
- AMD FX 8320 - 8 Core CPU
- Evga GeForce GTX 1080 Ti SC Black
- Asus M5A99X EVO R2.0
- ADATA Premier PRO SP900 - 128Gb SSD
- Kingston HiperX 16Gb RAM
- Windows 10 Pro 64Bit - Version 1703 - OS Build 15063.540 (With all drivers up to date. Even the Windows updates).
Thank you!
EDIT:
I finally found the FIX to this rare issue! At least for me... A Microsoft level 2 support named Carlito helped me. Thank you man!!
You have to check for two things, and make sure they are set as I say below:
1. Go to Device Manager -> Network adapters -> Network Card -> right click -> Properties -> Power Management -> Make sure the first two boxes are checked, then apply and exit.
2. Windows Key + R -> gpedit.msc -> Computer Configuration -> Windows Settings -> Security Settings -> Local Policies -> Security Options -> find this entry "Shutdown: Clear virtual memory pagefile" -> right click -> Properties -> check "Disabled", then apply and exit.
After this, your PC should Restart and Shut Down with no issue.
My PC:
Thank you!
EDIT:
