hello i purchased used flaming blade gti...Board does not post..All i get is a1 on debug screen.I tried with i7 920 d0 and 1600mhz mushkin copperhead..I tested gpu on other pc and it works.What should i try or just ask for a refund.Thanks
A1 a common error rest the cmos and If you get the same error then just get a refund.
I have black screen (monitor is turned off) i put battery out for 20mins and still same....Its really weird because mobo looks like new...First i get c1 then c3 then a1
could be a bios defect yes the board new but it just happens. and instead of messing with it, it better to get a refund before they say "ok it because you temper with it" then you don't get a refund. And try using another brand or...
could be a bios defect yes the board new but it just happens. and instead of messing with it, it better to get a refund before they say "ok it because you temper with it" then you don't get a refund. And try using another brand or series because I herd that the series of motherboard has alot of flashing bios issues, unless you really like it.
