fps check + specs for my first build!
Mark_198
Commendable
Jul 17, 2016
24
Hey guys my specs are:
Gtx 750ti superclocked ( I would have gotten 950 but already bought this lol)
I3-6100 3.7ghz
8gb ram
500w evga psu
1tb internal hard drive
Just wondering if I can run GTA 5 and arma 3 at the max settings with however many frames. Also I have 2 more parts to order which is why I haven't built this yet.
I believe those games are largely single threaded and cpu limited. I think you will do very well.
What are the other parts you need to order?
Always order ram in a 2 stick kit for dual channel operation.
FWIW.
I will never again build without a ssd for the "C" drive. It makes everything you do much quicker.
120gb is minimum, it will hold the os and a handful of games. If you can go 240gb, or 500gb you may never need a hard drive.
I would defer on the hard drive unless you need to store large files such as video's.
It is easy to add a hard drive later.
Samsung EVO is a good choice.
FWIW.
My mobo is http://store.yahoo.com/outletpc/lj2861-gigabyte-ga-h110m-a.html and I got a 1 x8 stick of ram.. Cooler master n200 case along with the hyper 212 evo fan.. And other specs are in OP.
