FPS drops close to smoke, CS:GO - semi pro needs help
niko3688
140
Hello forum, im playing semo professional csgo and i have a pc problem...
Problem: The problem is my FPS drops a lot when im close to smoke, but inside and on long distance no fps lag..
I've tried launch options command, cfg commands, resolution fix, everything i think - Anybody there can help me?
Specs:
Geforce gtx 660
intel core i5 4670k 3.40ghz
8gb ram
144hz benq monitor
I have now fixed this problem.. real-time audio
I who got wierd lags or stutter, go update your audio drivers, and your USB driver. Mine fucked it up
It's a exploit in single played sadly. Did you try going to the config in the CS:GO folder and changing some particle settings?
if you could read my problem, you would have an answer on that question... Yes i tried that
sorry for this late respons, forgot i had this, but i upgraded to a r9 290
i have now upgraded for about 3-5 months ago, but it didn't help out on the problem. any other things i can do???
Might Just be Game lag, Known problem, try reinstalling the game, It cant be the graphics card, it's unlikely that the graphics card would lag at such a specific part of the game. If the problem consists after reinstalling contact steam. Report the problem.
its not like only when im close to smokes, but really generally lags when i play and my fps reach 200-250 but yea, the problem shouldnt appear
didn't really help, but its a big problem for me, when im playing some turnaments - last week played a 2000$ turnament, not that easy with som lags.. 🙁
dude, what should i upgrade?? my GPU is almost as good as 970 my CPU is quiet good also, and im going to overclock, when i get my noctua dh15 - tell what to upgrade, and i'll think about it
cool give me a hit, and tell me what they say :) and thanks
One of my mates actually wanna buy my r9 290, so maybe i should get geforce 970
when im doing clean installs, im always downloading a new copy of the game - im not saving any old parts
