Hey guys,
So I'm in need of some help. I stream on Twitch and haven't had any problem with the games I play causing problems with OBS & playability .... Until yesterday.
I went to play Rocket League but the OBS fps dropped between 10-16 making it choppy. So, I switched to Rust only to fine that the fps dropped lower! (between 5-11), making the game & stream horrid.
The strange thing is, is I've played both these games before whilst using OBS, and everything was smooth, no problems at all. I'm confused as to what could have happened to change it.
I tested out Overwatch to check, and that was fine.
I tried changing the bitrate, lowering settings, changing servers, resolutions, checked for overheating, cleaned dust filters, checked for driver updates, ran virus & malware checks, checked wire connections, background processes etc.
My specs are:
Intel i7 7700k
Nvidia geforce gtx1070
asus prime zz70-k
Corsair 16gb ram
Corsair hydro H45
I'm not over knowable about these kind of things, hence coming here to ask for some help.
Thank you in advance x
My specs are:
Intel i7 7700k
asus prime zz70-k
Corsair 16gb ram
Corsair hydro H45
