Question FPS Drops on ROTTR MAX SETTINGS?
Feb 4, 2019
73
Hello, I need some answers with my problem
Whenever I look into some detailed trees (mostly on forested areas) on ROTTR, my fps cuts down to around 40-50. I just upgraded my RAM from 1x8 2400 mhz and I say it was a huge impact on performance. GPU and CPU usage are not even maxed out when the problem happens. Resolution is 720p
SPECS
Ryzen 5 2600 stock speeds
RX 5700 XT
2x8 16gb 3200mhz
520w SeaSonic s12II bronze PSU
TV monitor 720p 1920x1080 (24") @60hz (Yeah I know, I'll be getting my monitor soon)
Feb 4, 2019
73
CPU is about 40% and GPU is around 50 - 70% of usage, GPU temps are around 70-80c (It is hot here in the Philippines)
Game uses 6GB of ram and I'm using an HDD which probably could sometimes go a 100% while gaming.
Feb 4, 2019
73
There is one core (CPU8) that sometimes go 80% - 98% under stress but the others are just around 50-60 and sometimes 40.
Did I provide the correct info? Because I'm only a beginner at these things.
