So I've had a problem with games periodically dropping to 10-15 frames intermittently during gameplay. Whenever it would occur, I would check HWMonitor and almost always one of, if not several of the cores would be hitting 100%. I had this problem with an A10-5800K on a Gigabyte AMD FM2 A85X. I upgraded to my current build listed below and am still having the issue, although not as bad (optimized games like Overwatch and Rocket League barely stutter, but I am still dropping from 60 to 30 in some instances). I've run checks on my hard drives, installed the games on SSDs, cleaned out every part of my computer, reapplied thermal paste, rearranged fans, turned off Cool n' Quiet and Turbo settings in bios, to no avail. My build should handle games like No Man's Sky, Observer, Dark Souls 3, the Witcher 3, etc without dropping to unplayable stutters.
What are the steps I can take to diagnose the problem? I'm a novice and am unsure how to overclock if that could help.
Mobo: Sabertooth 990fx r2.0
GPU: Radeon R9 390
CPU: FX 8350
RAM: 16GB DDR3
PSU: Cooler Master GX - 750W 80 PLUS Bronze
CPU Fan: Cooler Master Hyper 212 Plus
OS: Windows 10
Thank you for any help!
GPU: Radeon R9 390
CPU: FX 8350
RAM: 16GB DDR3
OS: Windows 10
