FPS in games problem
Hynic
13
Hello,
I have big problem with fps in my games and i am not sure why ,because my pc is not that bad and my friends with lower configurations don't have any problems that i have 🙁
My config was:
CPU: AMD FX-6100
MB: MSI 760GM-P21
GPU: MSI Radeon 7750 2GB
RAM: 8 Gigs
PSU: Non branded 550W
HDD: SAMSUNG HD103SI
I had many problems on 1080p resolution , probably because my GPU was poor. After i got MSI 660GTX and Chieftec CHIEFTEC GPS-600A8 PSU i still have problems with every game , works good like 30 mins then start dropping fps ( games like WoW , Dota 2 , LoL , Wildstar..)
I would appreciate if someone could help me whats wrong with my config, why it lags not that good graphic or CPU intensive games?
Sorry for bad english !
The x1xx cpu cores are slower than the older phenom II's. The 6100 will bottleneck a 660 especially on games that require a decent cpu like most mmo's. The fx 6300 would be a big upgrade in terms of gaming performance.
Your Graphics Card IS sufficient to run the games mentioned,
I assume you have tried the usual suggestions such as:
Updating Graphics drivers and Windows to the latest versions
Checking Device manager to make sure all hardware is present and error free
Make sure dust is clear from case and all fans are running, Overheating and subsequent Throttling could be the issue. This especially applies to the graphics card fans. Download MSI afterburner + Core Temp to check your temps are not exceeding 85 degrees Celsius
Thanks
Sorry to be annoying at your english, but do you mean that its lagging with the GTX card? That card is much weaker than the 7750. Also, does it have issues on a lower res/setting on the 7750 too?
Think you better check your facts there bud. A gtx 660 is a lot better than a 7750, and actually about 10% better than the 7850. The bottleneck is most likely caused by your cpu. Any chance of overclocking it ?
I'll second that, GTX 660 is a very capable gaming card with much better performance than 7750
3D Mark shows a score of around 7000pts for the 660 and 3000pts for the 7750.
Everything is updated, i use legal windows 7 fully updated. Graphic drivers are also up to date. I check everything with driver checker.
Cleared case like week ago , no dust in it! Also my temperatures are around (CPU 50 degree celsius load , GPU up to 60 degrees celsius load)
I don't think so that 7750 ( 100€ ) is more powerful than MSI 660 GTX (185€) ?
System i use now is :
CPU: AMD FX-6100
MB: MSI 760GM-P21
GPU: MSI N660 Gaming 2GD5/OC
RAM: 8 Gigs
PSU: Chieftec 600W ( bronze 80% )
and my system still lags after 30mins of playing anything, why ?
after i spended 300€ to upgrade system from amd radeon 7750 and non branded psu to much powerfull 660GTX and branded psu!
I dont think so my motherboard is good enough to overclock my CPU?
Sorry, misread it as 6600GTX, its probably not the cpu though. That cpu seems ok, the MB has self overclocking, but I'm not sure about the safety of this.
