FPS Lag on Low Settings
PedestrianKiller
I just upgraded my computer's GTS 250 card to a GTX 750 and I tried playing BioShock Infinite. I tried settings at all ultra at first and it lagged, so I turned it down to very high, still lagged, and I went all the way down to very low, it still was lagging. I believe its my CPU that's bottlenecking the GPU but I just don't know how to help it.
HP Workstation xw8200
Processor: Xeon 3.2 GHz (2 Processors)
Ram: 4gb (DDR2)
GPU: EVGA GTX 750
That is an extremely old CPU based on netburst (9 years). Think pentium 4(which were awful). There's nothing you can do, the entire system needs replaced
So I used CPU-Z to check the type of processor and it doesn't give me the exact model.
http://imgur.com/jF1pr2X
This is absolutely correct.
I do not even think I would try Ultra or even Very High on my i5 750 an that is going on 5 years old now.
Food for thought, The E6400 from the Core 2 family was faster than a 3.7 ghz P4(and still faster than a 3.46ghz dual core P4 Extreme) while clocking in at only 2.13 ghz and consuming under 65 watts of power.
Things have moved along quite a bit. You do not have an upgrade path suitable for that system.
