fps limiter what number for 60 hz? 59, 84 or what?
helios411
140
With a 60 hz monitor what is the recommended fps limit one might set? I heard 60 causes worse screen tearing. I noticed that in this game Iracing the limit had by default been set to 84, so is 84 a good number and why would this be?
cheers
Unlimited is the best if you hope to limit screen tearing on a standard monitor. Locking at 60 is technically optimal and is what happens when vertical sync is set. Vertical sync is not perfect and causes tearing still. If you have a G-Sync or Freesync monitor with an Nvidia or AMD card, respectively, the technology in the monitor eliminates tearing.
