FPS max 40 after upgraded pc
Mar 31, 2018
9
Hey guys,
About my pc
-CPU (AMD FC(tm)-6300 six core 3,5ghz processor
-GPU (NVIDIA GeForce GTX 1060 6GB)
-8GB RAM
-Motherboard (ASR Rock 960GM-GS3)
-550 WATT
Hey guys, I upgraded my gpu to improve my fps, But ofcourse like usual i pay for something that didnt improve my pc!!! Im really unlucky with pc's somehow, Would love to game without lagg!
Problems
I play the game player unknown battelgrounds, I have like 30/40 fps
so really laggy, But thats not it it also drops to 20 so unplayble. I really really love to play this game ! i have the game setting on very low with those fps. I tryt many tuturial to improve fps on pubg but hnothing worked,
I really hope you guys can help me out!
Sorry for the bad english i tryt my best ! <3
Amd is going to be the more budget friendly option right now.
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor ($99.88 @ OutletPC)
Motherboard: ASRock - A320M-HDV Micro ATX AM4 Motherboard ($49.00 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-2666 Memory ($91.89 @ OutletPC)
Total: $240.77
Generated by PCPartPicker 2018-03-31 14:49 EDT-0400
or
Motherboard:...
Even low quilty it's 30fps, I checked canyourunit , I it sayt i can play it normally even with this cpu
but 30 fps with this cpu cpu is not the best but als not the wurst ?
The FX 6300 is the minimum cpu requirement for the game. Running a game using the min requirement in one or more areas usually doesn't offer a good experience especially with a game like PUBG that has optimization issues and with most multiplayer games the bigger the maps and or the more people playing can tax it more than they may have foreseen when writing the requirements
That old FX was an ok budget option a 4-5 years ago but will get beat in most games by newer $60 2 core 4 thread Pentium and is easily outclassed by a $100 quad core Ryzen.
Put simply if you want better FPS in PUBG you need a better CPU.
Given the extremely weak VRMs(only 3 phases) on the motherboard. I doubt overclocking will be productive.
Motherboard and 6300 seem the bottlenecks. 8GB Ram seems on the low side. The 1060 is old and tired. Yep -you screwed yourself with a sidegrade. Every 600$ Ryzen2/B350 Mb/16mb/SSD would be an upgrade to what you have.
1060 old an tired you'r kidding me rofl that thing isnt old @ all
Which CPU you suggest , im not rich xD , Like a budget cpu
and which motherboard you suggest aswell
The GTX 1060 is a good gaming GPU and is current generation. Most definitely not old and tired. Also SSDs do not increase gaming performance the best they can do for gaming is reduce load times.
You know a lot of pc's cant you benchmark my pc or somethings to still improve a bit for now with teamviewer orso ?? and which motherboard/cpu you suggest?
Total: $240.77
or
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($163.89 @ OutletPC)
Total: $312.77
Thanks for all the help! Best moderator ever ! Really helped me out gonna buy those thing ! really aprreciate the time / help <3 <3 <3 big love
