Fps not being capped @ 144fps
Aladdad
613
So since i bought a G sync 144hz 1440p monitor i've been reading on how to properly use G sync. from what i understand is enable g sync and V sync in Nvidia control panel. and disable v sync in game. for some reason my Fps goes 144+ in games which cause screen tearing. Which shouldn't be happening?
So yeah i would start by reinstalling your driver. Run DDU (display driver uninstaller) in safe mode then reinstall your GPU drivers and see if that makes a difference. regardless it sounds like something is not kicking in that should and this would be a good way to start with a clean (ish) slate.
