Fps problems in few games
Edvinas_3
Commendable
Oct 4, 2016
6
Hi,
I am suffering from completely random FPS drops in the game, after playing for like 30mins, fps drops from around 150 to 40-60, I dont think it should be like that.
My Laptop specs are:
Lenovo Y50-70
GTX 860M
Intel core i7-4710HQ
8GB RAM
Im running win10
Thats the temps when i get the fps drop:
https://ibb.co/m2WGNv
I think i have tried everything, nvidia share is off, drivers are up to date, xBox app is also turned off, power setting are on max performance as well. Any ideas what could be wrong?
Try all of the following :
  • Turn wallpaper into a solid colour
    Adjust settings for best performance
    Disable some startup programs
    Remove windows defender (if you have an antivirus)
    Make start and taskbar menu opaque
    Turn of tipping
    Download CCleaner and clean your PC, using the registry fixer
    Delete unnecessary programs
    Unpark CPU
    Go through files manually and delete old files and empty folders
    Run a disk cleanup
    Delete Cortana
    Delete Edge
    Download Defraggler and do a disk defrag, then stop windows defauld defragmenter
    Download driver updater and keep your drivers up to date
Ask if you want help on any of these.
If anything, your laptop GPU could be holding you back.
    Turn of tipping
    Unpark CPU
    Run a disk cleanup
    Delete Cortana
    Delete Edge
