FPS Problems in Multitude of Games
peppyrook
12
I just recently put together a PC that should be more than reasonable for most games I currently play, yet I'm getting unstable FPS rates through almost all my games. Keep in mind nothing has pretty much been done to the computer, aside from me upping the clocks for the GPU and memory by a ~170 and ~600 respectively. Even at their default clocks, the same problem stated below happened.
For an example, Nvidia's GeForce Experience keeps suggesting I at least put all the settings on High while also setting render distance to 6000, yet that barely yields me a FPS of 60 nonetheless a steady 60 nor 55; also the game feels minimally jerky (like a frame is skipped). Also, when I get into huge battles with multiple particle effects going off I drop down to about 40 FPS.
Air flow is great, GPU is clocked at 1420 while the memory is at 7600.
Listed below are all my parts via the dxdiag.
Things that aren't listed in spoilers:
Motherboard: ASUS Z97-A LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel
Power Supply: FirePower ModXStream Pro 600W 80Plus Semi-Modular High Performance ATX PC Power Supply 600MXSP, formerly PC Power & Cooling
CPU
Time of this report: 1/7/2015, 00:25:41
Machine name: M-PC
Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_r4.141028-1500)
Language: English (Regional Setting: English)
System Manufacturer: ASUS
System Model: All Series
BIOS: BIOS Date: 05/08/14 10:52:00 Ver: 09.01
Processor: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (8 CPUs), ~4.0GHz
Memory: 16384MB RAM
Available OS Memory: 16326MB RAM
Page File: 6550MB used, 12718MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.17415 64bit Unicode
GPU and other display info
Card name: NVIDIA GeForce GTX 970
Manufacturer: NVIDIA
Chip type: GeForce GTX 970
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_13C2&SUBSYS_85081043&REV_A1
Display Memory: 12068 MB
Dedicated Memory: 3906 MB
Shared Memory: 8162 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: HP 2511x LED Backlit LCD Monitor
Monitor Model: HP 2511
Monitor Id: HWP293C
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.4709 (English)
Driver Version: 9.18.13.4709
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Thanks for any help I can get.
Your GTX 970 needs 28 amperes on the 12 volt line, but your psu only gives 25 amperes.
http://www.firepower-technology.com/product/modxtream-product-family/
