Fractal Design Arc Mini R2 Case Review: For Your MicroATX Build
  • Thread starter Thread starter Guest
  • Start date Start date
Fractal's signature theme is a monochrome theme. Black over white or white over black. The only exceptions in their lineup will be the Blackout Edition case where(as the name gave it away) is going to be completely black - all the way down to having black drive sleds and fans with black blades.
https://www.youtube.com/watch?v=O8rDDyDW0yA#t=143
With advancements of manufacturing, all things tech that is white such as white PCB'd products and plastics won't turn yellow which apparently happens when exposed to UV radiation due to bromine in the plastic to act as a flame retardant.
http://en.wikipedia.org/wiki/Brominated_flame_retardant
Now due to various issues, the process has been changed, that's why you now see alot of white products NOT turn yellow within a few months.
Personally I love anything Fractal make, they are minimalist and functional!
Nice looking mature case. Just get rid of the awful side window (really, no one is impressed by whats inside) and its a deal!
I like the idea you can remove the drive cage. I can't stand cases with intakes whose air is immediately blocked by the drive cage. How effective is an intake that blows against a wall of metal?With these small cases, they need to just have one true 5.25 drive bay for optical and should adapt any other 5.25 bays to hold SSDs and HDDs. This way, the intake fans can blow freely across the motherboard. Most people don't need multiple optical drives any longer; especially not in a micro-atx case.
Also, there is no reason SSDs can't be mounted to the back of the motherboard trays. NZXT utilizes this design on a lot of their cases. You can even do this yourself without issue by just using some velcro if you have enough clearance between the motherboard tray and the case.
I think most people use their optical drives so infrequently, it makes sense to share a USB optical drive among all of your PCs.
I can see internal optical drives going by the way of the dinosaur; again, especially on a microATX build. Why are case designers still including so many 5.25 bays in general? More than one is hardly necessary for the average user. The only people who need multiple 5.25s are those with disk copying/duplication stations. Most of us aren't using our PCs for this purpose and if we are, we aren't doing it in a microATX package.
There are other uses for 5.25 bays than just optical drives. Hot-swap HDD/SSD, aftermarket fan controllers, card readers, front panel ports, the list goes on and on.
What's up with the white case fan? Won't it turn yellow once time and dust have a go at it?
I've had a fractal case with white fans for about a year now and they're still as white as they were when I first got it. Also has a white NZXT fan in there which is 3-4 years old and is still white.
Fractal designs fan controller can kill your CPU!
If it is the same fan controller as R4 (very likely) then it works like this:
12v mode: 12v from molex to ground
5v mode: 5v molex to ground
7v mode: 12v molex to 5v molex
The problem is the 7-volt mod that Fractal Design used. They claim that it´s okay to force up to 15 watt of power backwards into the 5v line. It´s not a good thing to do according to these links:
http://www.silentpcreview.com/article6-page1.html
http://www.overclockers.com/forums/s...d.php?t=372297
http://www.jonnyguru.com/forums/showthread.php?t=3917
http://www.ithinkibrokeit.co.uk/arti...vmod/page1.php
I have a R4 and FD Norton 600w PSU. When I used the 7-volt mod it destroyed my 4770k AND my replacement CPU G3225… and this is with their own PSU. The computer worked fine just up to the 7-volt mod. I contacted Fractal design about this but they can’t see a problem and they do not have the time to investigate it. I´ve wrote about it here but it’s unfortunately in Swedish:
http://www.sweclockers.com/forum/74-chassin-och-nataggregat/1283945-newton-600w-define-trasig-4770k/#post14450237
What 7v mod? my CPU runs fine.. I just keep all fans on 12v with the fans they provided.
It´s risky to change the fan controller from 12v to 7v or from 5v to 12v when the computer is running. Or use a pump with a delayed start as I did.
hi I was wondering im having to build a computer out of spare parts of some old tower and I was wondering if someone could tell me or point me in the right direction on building a custom case for my system unit? any takers?
