J Jereez Commendable Aug 7, 2016 34 0 1,530 Jan 11, 2017 #1 i have a fractal design core 1000 usb 3.0. How can i open the front ? I dont want to force it, and break it.
Solution Dark Lord of Tech Jan 11, 2017 To remove the front panel using the handle in the bottom, pull outwards and the front should come off. Fractal 1000 Manual states ^ http://support.fractal-design.com/support/solutions/articles/142824-core-1000-usb-3-0-product-manual
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,817 1,871 159,590 Jan 11, 2017 Solution #2 To remove the front panel using the handle in the bottom, pull outwards and the front should come off. Fractal 1000 Manual states ^ http://support.fractal-design.com/support/solutions/articles/142824-core-1000-usb-3-0-product-manual Upvote 0 Downvote Solution
