Fractal Design Define S side panel on Define R5?
Qwertyfish01
Commendable
Apr 20, 2016
30
I was looking at some cases that I could buy and came across the Fractal Design Define R5. I loved it. It had two 5.25 inch drive bays hidden by a door, perfect for what I need, plenty of space, and excellent cable management, not to mention the build quality. But there was one problem, and that was the side panel window. It's little. Later I came across the Define S, without the all-important drive bays, but has a huge window. Everyone says that the R5 panel can't go on the S, but can the S window go on the R5?
Not without jury rigging the latch on the R5. The S is a few millimeters different in size as well. It probably wouldn't look good at all.
You might be able to mod the existing side panel, though.
